![]() | Home > Technical (L322) > L322 TDV8 Heavy Power Steering - PLEASE HELP!!! |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
i had a number of issues and one of them was heavy steering at times also would not self center at times
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35649 ![]() ![]() |
i was going to suggest the servotronic valve but you've replaced that already...i would double check that the sensor cable going to the valve is making a proper contact though..
neiloakley Member Since: 15 Aug 2014 Location: Essex Posts: 7 ![]() ![]() ![]() |
@Stan - Thank you. Fuse in the GEM? Did not know that. Will check.
the fuse appears to be in the gem or it could be the fuse in the fusebox that powers it, not sure.. |
Got it - page 536 of 3104 |
I reckon it's in the fuse box, as the diagram shows it's hardwired to the GEM, not installed in the GEM. Else it would also suggest the servotronic valve and the ABS module are also inside the GEM ![]() |
