Home > Technical (L322) > height sensor
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
height sensor
Hi
Could someone tell me, if I disconnect a rear height sensor, to clean and lubricate, do I need an iid tool to reset, or will it be ok to just plug in again?
Post #275507 12th Aug 2014 5:24pm
It will be ok to remove and refit.
Not sure I understand what you hope to achieve by removing and 'attempting' to clean. They are sealed units that are non serviceable. New ones are not expensive but do require to be set up when fitted
Post #275515 12th Aug 2014 6:12pm
SFM
I just really wanted to clean the electrical.connection.
It seems.to.be sitting a bit low on one side, air bag seems ok, does not drop overnight ect
Thought it would be worth a try
Post #275521 12th Aug 2014 6:36pm
You could try some spray cleaner in the plug and socket
Post #275571 12th Aug 2014 9:16pm
