Home > Technical (L322) > electrical library |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35412 |
in a rar format for download,
12th Aug 2014 4:29pm |
RJPotts Member Since: 19 Aug 2021 Location: Durham Posts: 207 |
Hi Stan, I don't suppose you know of a newer version of this do you? Thanks & best regards Richard 2010 Range Rover Autobiography TDV8 Santorini Black 2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone] 2003 Range Rover HSE Oslo Blue [Gone] 1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone] 1990 Camel Trophy 127 (Workshop Vehicle) [Gone] 1989 Camel Trophy 110 (Workshop Vehicle) [Gone] 1998 Camel Trophy Freelander (South African Team Vehicle) 1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone] |
9th Dec 2021 5:42pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7827 |
I thought for the later cars, it’s part of the Workshop Manual, that’s in the Wiki for download.
9th Dec 2021 5:45pm |
Thanks...... We might be thinking of different things though........
9th Dec 2021 6:23pm |
Ah, see what you mean. I used the old docs and RAVE when I had my TD6.
9th Dec 2021 7:16pm |
Pity the details are in a separate doc but I suppose that makes it easier to refer to the diagram and the library at the same time.
9th Dec 2021 7:23pm |
peternicholls Member Since: 12 Mar 2022 Location: Stoke-on-Trent Posts: 36 |
Hey, I’m struggling to find how the front electric fan is wired up in my 2007 tdv8 3.6. None. Of the electric guides match up with the details at all. I have the engine wiring and it just shows and ecm pin out to ‘control unit - cooling fan’ and from there is a mystery! Any insights please? Error fault code on this |
2nd Jan 2023 8:14pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Have a look on 'engine cooling' rather than 'electronic engine controls'. |
2nd Jan 2023 8:25pm |
that is indeed what I have been looking for. All the info I can find is on the viscous fan. Nothing about the mysterious box called ‘control unit - cooling fan’ (D241) on contact C0005-4. This is clearly just a control signal wire. But details about the front cooling fan are almost non existent? I am dyslexic, so please bear this in mind. It clearly is getting in the way of finding hard to find info |
2nd Jan 2023 8:41pm |
Second page, where there are optional circuits marked with } then follow the circuits marked 'DV8'
2nd Jan 2023 8:56pm |
Thanks. How did you find this? Was there a direct link in the wiki? Why isn’t it clearly laid out to find? Everything is only organised once you know where to look. Electric diagrams should be under electric diagrams. |
2nd Jan 2023 9:27pm |
How can I find all the diagrams for this period in one place? It’s not logical where to look and I’m having to rely on others to show me. |
2nd Jan 2023 9:30pm |
Sorry another question? How do you find soldered joints? None have gone so far as I can tell, but are they randomly located? Or is there a guide for this? |
2nd Jan 2023 9:34pm |
I downloaded all the relevant diagrams for my L322 from Topix whilst I still had unfettered access, you can buy access for a day for a single Model / VIN for a relatively small cost and you're free to download as much or as little as you want within the time period you've paid for.
Usually they need to be exposed 'manually' or can sometimes be 'seen' using specialist kit like a Time Domain Reflectometer, or an Infra-Red camera. In reality, there are few problems with SJ's, the ones that are problematic tend to be well-known within the workshops and located with the minimum of fuss & time once confirmed through tests. ETA - an example of SJ locations, from the 'battery mounting and cables' diagram - a much underused but very useful sheet. |
2nd Jan 2023 9:52pm |
