Home > Maintenance & Mods (L322) > Pumping diesel into engine
Trossachsturbo
Scotland 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Help needed, have had some issues with increase in oil level on dipstick, so changed all seals and engine started after bleeding and ran great for a few minutes,turned off to check oil levels and found diesel right up dipstick, turned ignition and pump running and filling engine with oil. Drained all again, I think the timing is ok as it started and ran fine, I did wash the injector harness in paraffin. Is it possible fuel regulator is not allowing return? Vehicle now stuck across drive!!!
Post #275483 12th Aug 2014 3:46pm
Weegie
Injector seals need replacing.
If not the cylinder head gasket may have gone .
Others will have further options.
EDIT: Don't try to run it until you find the problem. Diesel in the engine oil dilutes it and can lead to damaged bearings etc. John
GAP iiD BT-Sold
Post #275489 12th Aug 2014 4:06pm
Trossachsturbo
Sorry guys posted this on this forum,by mistake,should have been on Def2 net!!,
Post #275493 12th Aug 2014 4:34pm
