![]() | Home > Maintenance & Mods (L322) > Washer Jet Bumper Insert? |
RangeK1D Member Since: 21 May 2013 Location: Calgary, Alberta Posts: 163 ![]() ![]() ![]() |
So found out through CamTech Craig that these washer bumper inserts are not sold separately but rather a part of the bumper itself. So folks if looking for a bumper for a 2010 facelift make sure it has the washer inserts because you won't be able to buy them as a separate land rover part.
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Long shot, but would the sport ones fit with a bit of fettling / adaptation?
Paul, the issue is with a plastic spacer/locator panel which gets plastic welded to the inside of the bumper that is missing on Asad's bumper! They get removed by people like Overfinch to fit inside their replacement bumpers and are NOT available to purchase from JLR!
Sorry to digress On a related note when doing my conversion I note the parking sensors came with rubber washer inserts. I fitted these once it had inserted the parking sensors into the bumper . Thing is should these be pushed in from outside or inside of bumper as although they look fine I notice the rubber washers whilst flush with bumper externally annoy me when washing car etc. have I put these in correctly? Present :2008 TDV8 HSE
Hey Googsy, I think they might go from the inside out. Insert your rubber onto the sensor first and then stick it in the bracket made for the PDC's. Zambezi Silver Range Rover (2010 Autobiography Facelift)
