Home > Technical (L322) > Air suspension -December 2003 RR Vogue Td6
RR1234
2014 Range Rover Autobiography SDV8 Luxor
My front air suspension deflated from off road mode whilst stationary and engine switched off! I now have the rear of the RR at high and the front with its nose almost touching the ground 100 miles from the nearest RR service option. Not a pretty site - looks like a dragster. Can the air suspension be reset easily or is this a case of replacing the front bag(s)? Big Cry
Post #274257 4th Aug 2014 4:04pm
When my front bag went it dropped but filled itself back up....
I'd check the front sensors, could be one has popped off, they are only push fit items....
What the dash saying?? Pete
Post #274263 4th Aug 2014 4:50pm
RR1234
The dash ain't saying anything. Thanks for the suggestion - I'll have a look. They are easily accessed? They just pop back in?
Post #274288 4th Aug 2014 7:10pm
Do you have any kind of diagnostics to hand or nearby?
If you have a fault, you will need this to reset/restart the Air Suspension. This should at least pump it up and indicate if you have a leak or problem with sensors. .
Post #274322 4th Aug 2014 9:29pm
RR1234
I just noticed when I drove the car a short while ago the Message Display reads...Air Suspension Inactive
I will see if I can get a diagnostic closer than 100 miles away! Thank you
Post #274329 4th Aug 2014 9:47pm
RR1234
New suspension airbag being fitted on Friday. A Dunlop bag at £150 plus labour - a fraction of the cost of a RR bag Smile
Post #274700 6th Aug 2014 6:02pm
Dunlop are the cheapest but apparently they don't last long... Delphi are a few quid more and supposed to last.... Pete
Post #274882 7th Aug 2014 9:59pm
RR1234
Thanks for that - I collect the car tomorrow with Dunlop fitted! I'll keep the site informed of durability.
Post #274905 7th Aug 2014 10:51pm
