Home > Technical (L322) > Cooled/ventilated seats
countryboy
2007 Range Rover Vogue SE TDV8 Stornoway Grey
Morning all,
I've got a new TDV8 (2007 Vogue SE) and love it, so much better than the TD6.
A couple of niggles though, the ventilated seats dint seem to blow any air on the back bit of the seat? The fan is working, I can hear it, but no effect felt? Also on the other seat, the air is a bit lack luster on the bottom part too.
Any ideas?
Cheers, CB
Post #274601 6th Aug 2014 6:13am
you dont get a significant amount of air coming from the seats but enough to cool you down...have you got the 'back' and 'seat' lights lit on the control knob.. ... - .- -.
Post #274604 6th Aug 2014 6:20am
pld118
@CB, ours has cooled/heated seats and for sure the seat/bottom parts of the seat benefit from the strongest cooling and heating aspect and because the seat bottoms perform so strongly, it can indeed seem like the back parts don't work quite as strongly. I'm sure I've read on the forum before that this is just how they perform and it has never bothered me because both parts do work.
As for one weaker output than the other, I'm sure someone else will be along to explain that... And also to tell me that our seat backs must be faulty Wink
Post #274605 6th Aug 2014 6:20am
countryboy
Yes, the lights are on and fan appears to be working..!
Post #274610 6th Aug 2014 6:29am
countryboy
pld118 wrote:
@CB, ours has cooled/heated seats and for sure the seat/bottom parts of the seat benefit from the strongest cooling and heating..............
Great, it's not just mine then! Yes the driver's side is so much more powerful than the passenger's side.
Post #274611 6th Aug 2014 6:30am
pld118
Can't help you with the performance of one seat being greater than the other... Unlikely to be this but presume you've hoovered, lightly brushed and cleaned the perforated parts of the seat to ensure no build up blockages?
Post #274615 6th Aug 2014 7:02am
There are serviceable filters on all four blower motors... Worth changing them first!
White disc filters (you can see them under your seats) Thumbs Up
Post #274617 6th Aug 2014 7:30am
the filters are an interesting point craig, are they easy to 'look' at.. ... - .- -.
Post #274627 6th Aug 2014 8:12am
There are one under each seat and one inside the rear removable (hard back) cover Stan... The ones under the seats are easy to view... Thumbs Up
Post #274638 6th Aug 2014 8:50am
i suppose they can get dirty and restrict air flow a bit..another job to do Laughing ... - .- -.
Post #274650 6th Aug 2014 10:48am
countryboy
Good shout, how does one remove the back of the seat, I can't see anything obvious and don't want to break it..!
Post #274676 6th Aug 2014 2:06pm
pld118
@cb, if not your filters as mentioned by CTC, this linked thread will take your OP to a whole new element... Ahem Very Happy
http://www.fullfatrr.com/forum/topic22581.html?
It's worth a read for reasons that include this summarised aspect of the post about removing the seat back:
"... To remove the seat back first unhook the leather flap that's tucked under the bottom of the seat (on elastic hooks). If I remember correctly the seat back itself is held on by two Torx screws, one in each bottom corner screwed vertically upwards underneath. The seat back should then pull upwards if you prise the bottom out first (the top is held in by plastic vertical slots so don't pull it any other way!). I don't think you need to remove the arm rest, it slots around it but check before man handling it! "
Post #274677 6th Aug 2014 2:22pm
countryboy
Cheers chaps, I'll keep you posted!
Post #274681 6th Aug 2014 3:24pm
