Home > Technical (L322) > Pulled out fuse 25 now car is having a fit.
rich89
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I accidentally pulled out fuse 25 whilst the ignition was on and now the windscreen wipers keep going off and when I put the key in the ignition the needles flutter about and when I try to start it, it just makes that starter motor noise and won't start and the dash goes dead.
What the Censored have I done??
Post #274267 4th Aug 2014 4:09pm
Sharp intake of breath thro clenched teeth.....Not fuse 25. Whistle
Try a battery disconnect and reconnect first and see what happens. Thumbs Up
Post #274270 4th Aug 2014 4:19pm
rich89
Just tried resetting it.
When I turn the ignition on, it comes up with hdc fault, transmission fault etc just makes a clicking noise and the dash goes blank and won't start.
Seems they are all something to do with the immobiliser
Post #274271 4th Aug 2014 4:22pm
Is your battery fully charged?
Post #274272 4th Aug 2014 4:27pm
Disconnect battery, wait 10mins, reconnect, make sure all doors and bonnet are shut, lock and unlock car with remote and then try it... had a similar issue with mine and that sorted it...
Good Luck Pete
Post #274273 4th Aug 2014 4:28pm
rich89
Battery is stating 10.85. Is that fully charged?
Post #274275 4th Aug 2014 4:39pm
nope.... ... - .- -.
Post #274277 4th Aug 2014 4:41pm
rich89
What should it be and can I buy a charger from Halfords and charge it whilst in the car?
Post #274278 4th Aug 2014 4:46pm
Your battery is flat, should be at 12.6V
You could either get a jump start and then go for a run to charge it up or buy a battery charger and charge on the car.
I'd be inclined to charge it with the -ve battery terminal disconnected depending on the type of battery charger you buy.
Post #274279 4th Aug 2014 4:54pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
I would jump it first to ascertain that it is the battery, use the body mounted +ve and -ve terminals, not the battery itself Thumbs Up
Post #274280 4th Aug 2014 5:01pm
rich89
Just jumped it. Car running is about 13.10.
Now if you could all please turn your attention to my post in 'in car electronics' I would be most grateful.
Post #274283 4th Aug 2014 5:11pm
If 13.1V is with the engine running after a flat battery it's definitely not very good.
I would take the car for a good run to charge the battery and if possible also see what the battery voltage is when running.
You should be getting 14.2-14.4V with nothing switched on.
Post #274285 4th Aug 2014 5:40pm
