Home > Technical (L322) > Fitted new compressor and fault still showing up.
rich89
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
As above, fitted the compressor and then had someone come round to clear the fault for me last night.
Went to the shops just now and on my way home after a 10 minute drive, it came up with suspension fault again.
The fault was that it was taking too long to fill up.
Any ideas?
Post #274034 2nd Aug 2014 3:53pm
87RJD
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Is the compressor you've fitted new, second-hand or refurb?
Post #274035 2nd Aug 2014 4:05pm
rich89
Brand new from duck worth.
Post #274036 2nd Aug 2014 4:10pm
Mikey
Corroded/Leaking reservoir?
Post #274037 2nd Aug 2014 4:12pm
I had a split in an air hose giving the same error. It was behind the offside rear wheel as the pipe comes out of the wheel well. If its taking too long to lift the car, the air must be going somewhere, so it should be possible to hear if you have a leak.
Start the fattie lifting then quickly switch off, jump out and listen........ Previously..
Post #274038 2nd Aug 2014 5:11pm
rich89
Doesn't seem to be leaking anywhere. I will check tomorrow again just incase the new compressor has pumped it up abit more than the old one.
It goes up and down so easily now tho. Doesn't struggle at all which is nice.
Post #274039 2nd Aug 2014 5:20pm
What is the fault: as read by diagnostics ? .
Post #274073 2nd Aug 2014 9:19pm
rich89
Before I fitted the compressor it was, reservoir too slow to fill up. code was C2A160 or something like that.
I haven't got a fault reader so haven't had a chance to read it post fitting.
Post #274079 2nd Aug 2014 9:44pm
