Home > In Car Electronics (L322) > DAB and Ipod addition
Ningr
United Kingdom 2005 Range Rover Vogue 4.4 V8 Adriatic Blue
http://www.halfords.com/sat-nav-audio/car-...io-adaptor
First of all this may not be to everyones liking, it is a heath robinson add on module that requires an additional aerial with 5v dc supply, and a cigar lighter plug in requirement.
Obviously if you have a little electrical connection ability these can be sourced via the rear of a switchable power supply or it will be permanently on and drain batt.
So, this is a small box that searches for a DAB station, stores it, then searches for more etc, until it has all your local stations. You then tune your FFRR radio manually to the DAB frequency e.g. 87.6
After that all your DAB stations are broadcast via your FFRR system - piggyback technology.
Also you have a line in / line out connection to enable you to plug in your iPhone via the headphone output of your pod.
Yes you do NOT have touch screen song identification etc etc but at £50 + cost of an aerial £20 i have DAB radio and my playlist available.
Post #273962 1st Aug 2014 7:05pm
