![]() | Home > My Range Rover > Project Fatty off roader....PICTURES NOW BACK |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8374 ![]() ![]() ![]() |
Thanks chaps, Gaz I appreciate the snorkel isn't water tight... I've got several tubes of tiger seal!!!
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
I had an intermittent starting issue. It turned out to be the starter motor. |
I did consider that but I'm pretty sure it's the ignition, seems to be a weak point on these, I'll give it a good clean and see if that helps... Pete
Which snorkel would you plan to use and where would you seal it too on an L322, even the G4 had no snorkel due to location of air intake... |
I know is not straightforward and I haven't fully explored the issue, the l322 intake appears to be at the front of the inner wing, same place as the Disco, need to fabricate pipe work from there back to the snorkel which should fit without too much modding, the screen angle is the same and it has clearance for the clam shell bonnet, I've successfully used water pump intake hose before as this doesn't collapse, and you can heat it and bend it a bit... Then it's just a matter of sealing the original intake....
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
"IT LIVES" is the main thing. Congrats. |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
Spot on topic, been reading with interest. Although will not be using ours for off roading, found loads of tips for repairs, etc.
Thanks Guys,
Jeez! That poor Discovery needs some TLC. |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
As always an enjoyable read mate. Hope the new hips get you back to 100% again. |
Cheers Paul
The starter motor has been screaming like a scalded cat for the last few days, working OK and spinning up well but sounded like a dry bearing, took it off to have a look and found this....
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Pete, keep up the good work fella, I love your updates and wish I had the time/mechanical ability to fettle with my RR to the same extent (taking the drivers door card off for the 3rd time this weekend to hopefully finally sort drivers door central locking which hasn't worked since I replaced the exterior door handle cable....) |
Great read. |
