Home > Technical (L322) > Air Suspension Inactive?
ibb1
After I had a new battery installed last week I had this warning come up, the normal turning the wheel left to right didn't clear it so the garage re set it on the computer.
All was fine until today when I got the warning up again, I had it reset on the computer again only for it to appear again half an hour later, the car seems to sit in the normal mode but it is locked in this mode only and I get the warning on the dash.
Does anyone have any ideas where to start?.
Post #273644 30th Jul 2014 5:24pm
low charged battery?.....was the new one that was fitted fully charged? ... - .- -.
Post #273650 30th Jul 2014 6:04pm
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
I go with Stan on this one. New batteries should be charged before being used. They could have been sat on a warehouse shelf for months before you get your hands on them.
Post #273676 30th Jul 2014 8:55pm
ibb1
Hi yes it was charged and conditioned before being fitted, I've heard the compressor working etc and it went up and down fine before this, does it need testing for leaks or could there be a compressor problem?.
Post #273712 31st Jul 2014 12:00am
i think the most easiest thing to do first is to disconnect the battery, wait 30 minutes, reconnect and set the steering parameters...if the problem is still there it would be a good idea to get the fault codes read .. ... - .- -.
Post #273742 31st Jul 2014 8:26am
