![]() | Home > Technical (L322) > Whine noise on take off and slowing down. |
Just noticed a new sound this morning sounds like a whine but disappears as car goes faster. I have tested car in neutral and revved engine and sound is audible at low revs then disappears until winding down so noise is not drive train related. I have no noticeable decrease in performance or increase in smoke. Thinking it might be a split turbo hose which I know can be common. Anyone confirm that's what it might be or maybe suggest alternatives? also excuse my lack of tech knowledge but are turbo hoses on tdv8 the 2 pipes that go into radiator? can't check as pitch dark outside.
Yes not a bad noise or loud but noticeable. Present :2008 TDV8 HSE
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Could be bearing on the alternator or one of the aux belt tensioners 56 TDV8 Vogue SE
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 ![]() ![]() ![]() |
A split of any size in the turbo pipes to intercooler would def result in loss of power I would guess tensioner/pumps etc Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 218 ![]() ![]() ![]() |
I just had this problem. I let my local dealer have a listen to make sure I wasn't hearing things and after they inspected the engine bay with the engine running they found that one of the turbo hoses was torn as shown in the first photo. Cost me 110EUR for a new one because it comes in a three-part set (part no. LRPNH500460) shown in the second photo. Working fine now, though |
Hmmm, spoke too soon. After a long trip to the Alps and back the noise has returned, if not quite as loud as before... |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Girlfriend/wife Conner ![]() ![]() ![]() |
