![]() | Home > In Car Electronics (L322) > Venture Cam |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 ![]() ![]() ![]() |
Sph, if you have one ( which i believe standard on your model) sit in passenger seat, cubby hole at knee level next to door on left side,, should be in there, if not then charger/connector will tell you if car had one |
Capers Member Since: 07 Jan 2013 Location: manchester Posts: 14 ![]() ![]() ![]() |
Unnecessary quote removed
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35490 ![]() ![]() |
not all FF's came with venture cams ..afaik it was an option from around 2008 .. ... - .- -.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
My 2008 VSE doesn't have one. Never had the need for it TBH Got - 2017 SDV8 Autobiography in Loire Blue
Vorbis Member Since: 18 Jun 2014 Location: Pebmarsh Posts: 147 ![]() ![]() ![]() |
Just bought one for £26 off of eBay, not sure I'll ever use it though |
Buying the cams the easy bit, it's the wiring for the charger that's challenging |
....and the activation on the ccf.. ... - .- -.
Mine had the charger, so it wasn't that hard |
