Home > Technical (L322) > Towbar from 02 FF to MY11 4.4
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Hi,
Can anyone tell me if I can take off my towbar armature (westfalia) from my '02 FF and fit it to a 11MY FF ? I tried searching and discovered it fits 06-10 MY but nae sure if there was any change in 11/12MY
Many thanks MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #271906 20th Jul 2014 3:20pm
Q86ARR
2015 Range Rover Autobiography 5.0 SC V8 Havana
I'm pretty sure that the armature will be a straight swap.
You will need new towing electrics though.
Post #273323 28th Jul 2014 9:44pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Later type has different exhaust hangers if I am not mistaken, not insurmountable from what I have read. 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #273326 28th Jul 2014 9:51pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
You will need to cut the right angle brackets which hold the exhaust mountings off the 'crash bars' on the new car when you remove them, then all will be fine (will make sense once you look at how the exhaust is mounted on the later car - a little different to the early car - the exhaust mountings on the early armature are not used).
Pics below are from mine - 56 Reg using earlier armature, fitted a couple of months ago, also, as said in previous posts, the electrics are different on your new car and will need to be enabled by a dealer or using an IID tool or suchlike.
If I can be of further help, PM me with your mobile no and I'll give you a ring. Thumbs Up
 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #273381 29th Jul 2014 10:23am
woodchopper23
Thank you very much. i just need to find a replacement for my old 2002 v8. MY2010 TDV8 Vogue Ipanema Sand
Post #273399 29th Jul 2014 11:19am
