Home > Maintenance & Mods (L322) > Can you change the TV to receive a Digital signal!
kil2508
Wales 2005 Range Rover Vogue Td6 Java Black
Hi Guys
Looking to buy a range rover, and here in Wales we have already switched over to the digital signal, is there anyway of modifying the TV in the Range Rover to receive a digital signal?
Cheers
Gav
Post #27263 5th Sep 2010 11:59am
RRV
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
Buy a newer Range?? If you have nothing nice to say,say nothing at all.
Post #27266 5th Sep 2010 12:13pm
if you have only an analogue receiver then you'll have to buy a digital or hybrid one..plenty of posts on the forum re this , do a search... ... - .- -.
Post #27268 5th Sep 2010 12:19pm
dan_uk_1984
Search on eBay for BMW Hybrid:
http://shop.ebay.co.uk/?_from=R40&_trk...Categories
These may or may not fit yours, but they are the sort of thing you are looking for.
Dan
Post #27273 5th Sep 2010 12:48pm
daveo
there are two types, 02 to 05 bmw system 05 onwards ford based system..
go for the car pc ,cheaper and you will get far more out of it, as long as its a pre touch screen.
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #27275 5th Sep 2010 12:54pm
kil2508
Cheers for the replies guys, glad it can be done, just got to buy a Range rover now! Thumbs Up
Post #27276 5th Sep 2010 1:00pm
Discocuzzy
daveo
Daveo can you use the standard screen for the PC connect or do you replace that for a touch model?
I have all my Nav equipment running through a tablet pc in turn connected to a 7" lilliput touch screen running centrafuse in the Defender works very well but is designed to be totally removed in 2 mins, would love to hear your thoughts on a permanent solution for the 02-05 FFRR
Post #27299 5th Sep 2010 7:49pm
daveo
hi, you use the pre touch screen, the res its not brill but is good enough to do the job, there are a few people working on a screen replacement with a high res, just the screen so you get to keep the origanal unit and looks V8 facelift Range Rover Autobiography 22" wheels.
Post #27302 5th Sep 2010 8:47pm
daveo
hi discocuzzy i have not seen centrafuse, would like to see it if you have a link, i use carx as it replicates the range rover menue so when you switch over it looks the same... V8 facelift Range Rover Autobiography 22" wheels.
Post #27303 5th Sep 2010 8:53pm
Discocuzzy
Like it Daveo...what system you running, where is it hidden etc?..i have just aquired another tablet Thumbs Up
Post #27308 5th Sep 2010 10:37pm
daveo
hi, my set up is all in the boot, i use an acer one netbook with an external hard drive, this is connected to the car via video interface lead from the tv tuner, and is controlled by the usb ibus interface, this allows you to control it from the front, as i said it replicates the menu so unless you know about car x you are none the wiser.
then you have all the function of a pc, internet, external cameras,videos,music and of course digital tv.. V8 facelift Range Rover Autobiography 22" wheels.
Post #27309 5th Sep 2010 10:57pm
Discocuzzy
Are you using a 12 volt power supply that auto shuts down/powers up with the ignition?...also where do you get the leads to connect the TV?...sorry if to many questions pal Bow down
Post #27310 5th Sep 2010 11:24pm
Discocuzzy
Last one Dave i promise!!!. i run garmin sat nav for pc in the defender, would the standard screen allow you to run this as well?
Post #27311 5th Sep 2010 11:26pm
daveo
hi yes, the 12v supply is on the ignition, the pc is set to restart after power fail so when the batt goes flat as soon as the ignition is on it will restart but it very realy goes that far as the standby life is great,
you can get the video interface lead from ebay, they do two types, you want the one with the camera reverse input along with the switch wire the uses pin 17, when this gets a ground to it "from the ibus interface" it will auto switch the front monitor over to display what you are inputting on the reverse cam iput,ie your pc signal..
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #27312 6th Sep 2010 12:01am
