Home > Maintenance & Mods (L322) > Charging System Fault
wealy
Anyone local to me (Lichfield - Burton on Trent area) with testing equipmet (MY 2010) - I have had the dreaded "charging system fault)" warning message come up on the dash.
Belts seem fine and the car is starting OK for now????
Any offers!
Post #272555 24th Jul 2014 7:38am
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
No longer in that part of the world unfortunately or would have been glad to offer some assistance. Thumbs Up
If you have access to a voltmeter, try measuring the voltage across the battery with the engine running - you should see 14.5 - 14.7, if you do you can be reasonably confident your alternator is OK.
Have a look at the battery voltage then with the engine off, having left the car to stabilise preferably overnight - you want to be seeing high end of 12v here.
One thought, if your battery is original it is 4 years old now - could actually be on the way out?
If you do a search on here on 'charging system fault' I'm sure there is quite a lot of other info available.
Best of luck Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #272644 24th Jul 2014 4:36pm
wealy
Yea, did that the out put is only 11 volts.
Have had a good look around and this looks a big job. Im guessing the radiator has to come off etc?
Post #272655 24th Jul 2014 5:39pm
wealy
Speaking to people I'm guessing I don't need the fault codes read as this is a simple alternator failure? Any thoughts?
Post #272656 24th Jul 2014 5:50pm
Full Fat Ray
If you are only getting 11 volts when engine is running, your alternator is cream crackered sir (unless it is a bad / loose connection).
I'd check the connections / cables first. The workshop manual is on the WIKI here, that will tell you what is involved to replace the alternator if necessary - haven't done an FF yet so don't know if the rad needs to come off, or how big a job it is.
If you are only getting 11v when running, you will be draining your battery quite badly so I suggest you get a trickle charger on it pronto to fetch it back up again or you may end up having to replace that too (they don;t like sitting in a discharged state for any length of time, and if they are left like this they will no longer charge to full capacity, and we all know what that means on a FF - Gremlins!! Twisted Evil
With regard to the fault codes, you are going to have to disconnect the battery while sorting this out, which will produce a whole shedload of fault codes, so I suggest you solve your charging problems first, then get the codes cleared afterwards.
Post #272660 24th Jul 2014 6:30pm
wealy
Cheers Big Cry
Post #272676 24th Jul 2014 8:12pm
RJDS
United Kingdom 2011 Range Rover Autobiography TDV8 Bournville
Charging System Fault......
Battery reading 12.1 (Not rested, engine turned off)
Battery reading 12.21 when engine running...
Alternator gone I guess?
What replacement alternator should I get fitted OEM, Denso?
Thanks 2011 TDV8 4.4 AB Bournville Brown
Post #479403 26th May 2018 12:02pm
andygts
Non of the above, your alternator will just need a new regulator. Never done a range rover but I wouldn't mind betting it could be swapped while on the car.
You just need the actual alternator model info and find the parts
http://www.jcrsupplies.co.uk/products/ALTERNATOR_REBUILD_PARTS
Probably cost circa £30 Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #479414 26th May 2018 4:16pm
RJDS
Thanks andygts 2011 TDV8 4.4 AB Bournville Brown
Post #479430 26th May 2018 7:39pm
RJDS
Should the battery be recharged using a AGM specific battery charger or will the cars alternator recharge the battery back to a healthy condition.
Thanks
RJDS 2011 TDV8 4.4 AB Bournville Brown
Post #479871 1st Jun 2018 12:49pm
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Best to charge with a charger!! 2012 TDV8 Vogue SE 4.4
Post #479967 2nd Jun 2018 8:46pm
RJDS
All sorted....
Thanks for the help chaps. 2011 TDV8 4.4 AB Bournville Brown
Post #480304 6th Jun 2018 6:05pm
nino_nino
what did you ended up doing?
Post #480311 6th Jun 2018 8:29pm
RJDS
Replaced alternator. An absolute swine to get out.....
Then spent 10 minutes clearing the list of fault codes, thrown up as all the systems shut down. 2011 TDV8 4.4 AB Bournville Brown
Post #480337 7th Jun 2018 8:18am
