![]() | Home > Camping, Caravanning and Holidays > stabiliser advice |
wedgel322 Member Since: 20 Jul 2011 Location: Leeds Bradford Posts: 161 ![]() ![]() ![]() |
Just bought a starter caravan off a friend of a friend. Its an immaculate 1989 ab marauder 450si so a nice littlei van for us to try caravaning out. What I need advice with is this.... it has a stabiliser bar that connects from caravan to car which looks to be sprung but I am getting a towbar fitted on friday and wanted to get a detachable towbar. Will it still work? Or am I going to have to get fixed one which in my opinion look ugly.
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
^+1 what MrTee said.
mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133 ![]() ![]() ![]() |
That's the thing about forums you get both views ,lol no disrespect to Mr Tee but I always use a stabiliser if I can, I had one come loose years ago and left it off for a return journey, it was horrendous. You can buy a bracket that clamps to a quick release tow bar but make sure its very tight when you fit it. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8740 ![]() ![]() ![]() |
The above is true, bit on a abi marauder from the late 80 the MTPLM would be under 1000kg i reckon, so even a poorly loaded van would have very little impact on the feel of the car even without a stabiliser. I towed my avondale with my 5 series without a stabiliser and it was fine, but added one on a whim and there was an improvement, as you would expect, but it wasnt night and day better. As it was well loaded and light it was already Pretty stable.
Thank you for yout views. I do want to use the stabiliser as I am very excited about caravaning but nervous about something going wrong. U eill ring the towbar place in the morning. 2003 Range Rover HSE 3.0 TD6
Top tip i have is to join the caravan club, there are loads of sites round the country, all of a good standard, loads in good locations, and you can book online, without paying a deposit , and so long as you give good notice, cancel without a penalty.
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 ![]() ![]() ![]() |
I would go with a stabiliser every time. I prefer the type that are built into the tow hitch but the blade type you describe are a good alternative.
stevebrookman Member Since: 08 Jan 2010 Location: South Wales Posts: 50 ![]() |
Morning all,
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
^ Pretty much what they said after 1000's of caravan miles use a stabiliser and check your weight and loading.
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
+1 for joining the Caravan Club, not only access to their network of sites (we prefer the certified locations, smaller, less facilities but much cheaper). The other big advantage of joining the club is access to their excellent on line technical knowledge base. |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
The only reason that a stabiliser should be fitted is for when lorries etc. pass you which can effectively "suck" the caravan towards the lorry. The stabiliser will quickly bring it under control. A stabiliser will mask a badly set up unit and there is not a lot that can be done to bring that under control. If you stick heaviest items (crates of wine and beer) low over the axle and get the nose weight correct (a baton of wood and an old set of bathroom scales should suffice) then it will be happy days.
