Home > Maintenance & Mods (L322) > Removing top tailgate trim panels to fix rattles
I want to discover the cause of a rattle in the rear trim surrounding the top tailgate. Can't be hard.
Its the grab handle part, the lower trim as shown here:
I have removed the trim panel near the wiper motor before and its edges overlap the two side panels.
The clips look like this, and you just have to tug them really hard.
In Rave they show the clips looking like this and very little information to help...ignore the arrows, it the clip at the bottom I am trying to showcase in this pic.
Anyone know how to do this and have any advice? Discovery 4 HSE
Post #271966 20th Jul 2014 8:18pm
nobody got a clue??
Shocked Discovery 4 HSE
Post #272220 22nd Jul 2014 10:27am
Googsy
Based on clips it looks like it just pulls off? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #272226 22nd Jul 2014 12:13pm
^ It does indeed Thumbs Up Carefully.
Post #272228 22nd Jul 2014 12:22pm
What I want to do is once it's off, the stick the thick sound deadening material I have left over from doing the Defender, to stop the plastic resonating so much. Discovery 4 HSE
Post #272242 22nd Jul 2014 2:20pm
It's off! Discovery 4 HSE
Post #272246 22nd Jul 2014 2:33pm
So, with a modicum of effort I removed the trim panel and cleaned up the inside, then used leftovers from sound deadening my Defender, it's a sticky black thick foam with aluminium backing. It's very dense so absorbs panel rattle.
These plastic trims are so hollow and flimsy, it's no wonder they rattle over bumps and you get resonating plastic noises.
I filled the inside with the material then for good measure used a block of foam I had and cut some wedges, so that when it was put back together the air gap was also taken up. Then I used aluminium tape to seal between the material pieces too, neatens it up a bit.
Each tailgate light has a pathetic piece of foam surround and this is supposed to keep the panel from touching metal and resonating. It's not enough.
I also poked foam inside the side trims as you can see from my pics down below.
It ain't a pretty solution, but it works. Thumbs Up Discovery 4 HSE
Post #272267 22nd Jul 2014 4:02pm
 Discovery 4 HSE
Post #272268 22nd Jul 2014 4:06pm
Googsy
Foamtastic job Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #272272 22nd Jul 2014 4:42pm
