Home > Advanced Factors > BREMBO Disc & Pad kit offers
Page 3 of 3 <123
dingg1
got the check pads warning up this am
ordered a full set as on quick looksey the discs look to be quite well worn front and rear , good timing I'd say Cool
Post #266931 23rd Jun 2014 6:03pm
AndyBunn
Just got back from north devon l and noticed the steering wheel shaking on under light braking but seemed ok on heavy. Im guessing possibly warped discs. So just purchased a full set front and rear. hope this solves the issue. Razz
Post #266933 23rd Jun 2014 6:43pm
i'm sure it will andy..i had mine fitted on saturday and they are a quality item... ... - .- -.
Post #266948 23rd Jun 2014 7:53pm
dhallworth
I ordered rear Brembo pads, wear sensor and a fitting kit for our SC yesterday.
Order processed at 14:09, email received at 14:17 stating they were dispatched.
Email again this morning at 9:22am telling me when they would be delivered to within an hour!
Fantastic service that I'd certainly recommend to others and will definitely be using again!
Thanks very much.
One thing to note, the Brembo pads come with the fitting kit in the box so you don't need to buy one Thumbs Up
Post #267736 27th Jun 2014 11:49pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Got round to changing front discs and pads this weekend. The pins were a sod to get out (even with the springs depressed) However found best policy was to spray with WD 40, have a brew, then welly the hell out of them! A spot of hammer rash on base of left thumb later and out they came. Well impressed with the room to work around inside the wheel arch, which resulted in less profane language than usual. Used combination of supplied jack and axle stand to support weight with added security of bunging the wheel underneath. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #267994 29th Jun 2014 2:16pm
xjsracer44
United Kingdom 2007 Range Rover Vogue SE Supercharged Java Black
Just ordered a full set, as the check brake pads warning light came on last night, as expected.
AF site very easy to use and order acknowledgement received straight away. Thumbs Up
Post #272032 21st Jul 2014 12:50pm
xjsracer44
Pads & discs arrived today, 24 hours after ordering them Thumbs Up
They look so good in the boxes that it is almost a shame to fit them Cool
Being fitted tomorrow.
Post #272280 22nd Jul 2014 6:30pm
destructimo
United Kingdom 2004 Range Rover Vogue 4.4 V8 Epsom Green
Ordered a set of these the other week for the front as the check brake pads warning had come up.
Site was easy to use, order arrived quickly within 48 hours with all the bits you need. Decent looking quality, wear wire is a pattern part but fitted fine.
Fitted them with my handy oppo yesterday. Was quite straightforward. Caliper bolts were hard work.
All seems good, just bedding in at the moment.
I'll order another set for the rear to put on the shelf for when they need doing.
Cheers
Clive
Post #275611 13th Aug 2014 11:16am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Ordered front & rear discs and pads today.
Many thanks! Thumbs Up 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #285028 8th Oct 2014 1:43pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Hello Gents....pad warning came on this morning...how many mm of pad left when the warning illuminates? ( not asking for safety advice as know they'll need doing asap)
3.6 TDV8 with brembos
Ta.
PM2 GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #290579 4th Nov 2014 10:59am
you have a quarter left Paul..
from the WM,
The front brake pad wear sensor is connected in series with the rear brake pad wear sensor, in a circuit
connected to the instrument cluster. When a brake pad incorporating a brake pad wear sensor is approximately
75% worn, the brake pad wear sensor goes open circuit. When the instrument cluster detects the open circuit,
it illuminates the brake warning indicator (red), displays an appropriate warning in the message center and
sounds a warning chime.
Post #290581 4th Nov 2014 11:19am
paulmoran2
Cheers Stan Bow down GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #290582 4th Nov 2014 11:20am
paulmoran2
Santa's come early
Ordered yesterday, came today...great service from Steve and the guys at Advanced Factors
Guess i'm going to be busy tomorrow Thumbs Up
mmmm brembo's Bow down GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #291166 6th Nov 2014 12:01pm
M4TT53
Are these deals still correct?
Cheers
Post #439283 22nd May 2017 8:28pm
iani
2007 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I'm also interested in a kit, are these still available, I don't see them on your website?
Ian
Post #439989 29th May 2017 5:06pm
Page 3 of 3 <123
