groan .(((..more problems | |
OK so hopefully someone can help here please ...
My abs ecu decided to short circuit and fry my multi plug and wires a few weeks ago so i ordered the replacement loom that was part of the LR recall ( 2003 td6) , all the wires matched up apart from one of the wheel sensor wires which had a different tracer wire but seemed to match up .
I ordered another ABS pump from flea bay but the the numbers are slightly different but didn't think it would make a difference as from the same year of rr as mine.
Numbers are
584145 0 265 950 056 old
287298 0 265 950 056 new
So put it all back on and fired it up but got a steering angle sensor initialization error with some other codes on the ID tool ,( used the beta version 3 software to do this ,cheers to the GAP boys for product support ..SPOT ON !!)
SO recalibrated it but still got no Air suspension and abs /hdc fault.
Here is the codes i have coming up
Lateral acceleration open circuit
yaw rate sensor open circuit
ABS ecu coding error
EAS system , can bus error
Instrument pack ,acoustic transmitter fault
bd-ebv function fault received from abs ecu
the following codes only came up after recalibrating the steering angle.
Now before i recalibrated the the steering sensor i was checking the wiring according to the rave to double check , the wiring to the pin numbers on the new multiplug don't all match up with that of the Rave ? as in it says for example wire A should go to pin 5 etc etc ?
Have i got the wrong ABS ecu ? is that whats causing the problems?
Sorry for such a lot winded post .((( its doing my head in
