![]() | Home > Technical (L322) > Sloshing Water Sound Behind Dash??? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35494 ![]() ![]() |
sounds weird, i gather the water is in a container of sorts otherwise the electrics could suffer.. ... - .- -.
CyberMrT Member Since: 26 Mar 2010 Location: Stratford upon Avon UK Posts: 60 ![]() ![]() |
Yeah, it sounds contained in something like having a long bottle of water being tipped from side to side?
Follow these steps to bleed the heater system:
Cheers Dan, I'll give it a go when it stops raining.... |
Had a go at bleeding the system but havn't really been able to improve the sloshing sound?
Could you hear the aux coolant pump running? With your head in the engine bay you should be able to hear it, sort of like a quiet washer pump...
Oops, I think I gave you duff info with that. I think the small jet of water is the one to keep an eye out for if you're bleeding the main system... ![]() |
Ok, so I've tried every method of bleeding the coolant system but with no joy?
Just wondered if anyone else had any info on this????
Good news....possibly. |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
Thats good news CyberMrT - be careful with that drill though! |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 ![]() ![]() ![]() |
Crikey, it would make sense; i always believed it to be trapped water but no way of knowing where or how. I rang a combination 12 local and specialist RR garages yesterday but none had heard of the problem on a RR.
Yay, fixed it, I'll tell you how if you give me £1000.....(same as dealer price). |
mmmmm watch it pour....
