![]() | Home > LPG > Overfilling LPG tank confusion |
In the tank there is a little floater similar to the old tank floaters in petrol tanks. The floater is connected to the shut-off valve. Yours is clearly not working properly and I suggest that you get it replaced soon.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8514 ![]() ![]() ![]() |
As ebajema says the filling is controlled by a float on the inlet, in the UK we have a limit of 80% fill, this is never exact and does vary a lot, the reason for this is that it leaves 20% for expansion due to heat, if you filled the tank full (100%) on a cold morning and then left the car parked in the sun all day (with an internal tank) the LPG would expand and want to escape, all LPG tanks have pressure relief valves and this would open and vent the gas, that's why the tank fittings are in a sealed container that vents to the outside of the vehicle...
destructimo Member Since: 24 Apr 2013 Location: Kent Posts: 76 ![]() ![]() ![]() |
Are you sure it's a 76L tank and not a 95L?
Knightrider Member Since: 22 Mar 2014 Location: England Posts: 125 ![]() ![]() ![]() |
It's definitely a 76 litre tank as I have all the LPG installation paperwork with the car. I think the previous owner went for the 76 litre tank as it allows the spare wheel shelf to sit flat/flush wheras the larger tank means it doesn't sit completely flat.
I would still suggest to replace the floater/shut-off valve because it shouldn't do this. If the tank gets over pressurized the safety valve will vent it and dump it into the grey fittings box and via a rubber hose outside (underneath) the car. You'd smell a problem immediately (that is how I found out about my issue with the GMC).
OK, having driven gas tankers for a few years I'll tell you that the 20% ullage space is a massive safety margin. The tanks themselves can handle way more pressure than LPG could ever exert even in the hottest conditions. It was originally designed for bottled gas which has no PRV and can be left out in direct sunlight for weeks on end.
On the GMC I also reduced the fill percentage to approx. 95% because the tanks were deep down covered etc. And with a GMC, you reduce the volume in the tank quite quickly to say the least |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 792 ![]() ![]() ![]() |
Was talking to a potential lpg conversion customer at my mates place this week.Long discussion about the safety of the tank. He was asking about how they stand up to a crash situation. Pointed out two things to him. 1. the petrol tank on his car was made of plastic ! 2. There was a new doughnut tank awaiting use so I invited him to punch it hard. We stopped him seconds before he did having invited him to then bang it with a piece of wood. He's now convinced !! |
