Home > Maintenance & Mods (L322) > 2011 FF. do these have water ingress issues?
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
my 2007 FF had a plastic sheet covering the electronic modules in the boot are as a precaution against the dreaded water ingress issue. although it never afflicted the car.
i now have a 2011MY FF, do these cars have the same water ingress issues? worth getting a plastic sheet in the area?
cheers
raj 2011 4.4 TdV8 Nara Bronze
Post #270899 14th Jul 2014 10:13pm
I thought all 2007 ish onwards models had "water shedders" fitted...
Have they been deleted on later models then?
Post #270901 14th Jul 2014 10:25pm
maybe someone with a similar aged FF can have a look in the back of theirs and report.. ... - .- -.
Post #270956 15th Jul 2014 8:17am
mjdronfield
You mean you don't have a water ingress issue ?
Rolling with laughter
Thought the same seals etc were used across the life of the L322. Could be wrong.
I'd move it over or get another just in case. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #271041 15th Jul 2014 4:50pm
goldsax
come on ..
a dry FF can't be that rare Shocked 2011 4.4 TdV8 Nara Bronze
Post #271140 16th Jul 2014 7:12am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Used to get water in the spare wheel well, took 4 visits to the dealer to fix. Turned out to be the seam above the rear pillars.
The water appeared to run down to the rear so did not get into the electrics.
Ian
Post #271158 16th Jul 2014 8:01am
mjdronfield
To be fair, mine has not had a water ingress issue - touch wood.
I have fitted the water shedder just in case though.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #271254 16th Jul 2014 4:50pm
goldsax
'water shedder' i like the term.
so any 2011MY without a water shedder..... 2011 4.4 TdV8 Nara Bronze
Post #271261 16th Jul 2014 5:17pm
mjdronfield
That is the official Land Rover description for the plastic bag it provides as a precaution.
It's what it said on my invoice from the dealer.....
Laughing 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #271287 16th Jul 2014 6:48pm
