Home > Maintenance & Mods (L322) > Waterfall in car!
Turnover
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Waterfall in car!
Hi, had my motor for about a month now and with the standard uk summer weather now upon us I've noticed a major water ingress problem. After heavy rain I notice that when I open the drivers door water suddenly pours down the bottom door speaker and nearby. Any ideas?
Cheers Chris 2007 Range Rover Supercharged in Zermatt Silver with Jet Leather
Post #270613 13th Jul 2014 3:15pm
Door opening water is normally water getting trapped between the two door SEALS more common on back doors. Check both inner and out seals are undamaged and seated correctly although not sure how this could get to door speakers etc Shocked (Normally just dumps a puddle on your feet)
Post #270615 13th Jul 2014 3:19pm
there is a solution where you put a bit of wood on the bottom of the door and press the door against it causing the door to bend slightly....do a search its here somewhere.. ... - .- -.
Post #270618 13th Jul 2014 3:47pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
When I open the top half of the boot after heavy rain, waters always splashes on the the parcel shelf at either side. Any cure for this or is it a design fault ?
Post #270694 14th Jul 2014 6:48am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Yes, its a design fault feature Big Cry GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #270702 14th Jul 2014 7:26am
