![]() | Home > Wheels & Tyres > Tyre Pressure |
Normal load 33 front, 36 rear.
Vorbis Member Since: 18 Jun 2014 Location: Pebmarsh Posts: 147 ![]() ![]() ![]() |
Well just set them at the above and they look a bit flat |
What's the spare supposed to be at? Its at 36 and I'm getting warnings |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
if you have nexens fitted then they do look flat when at the correct pressure... ... - .- -.
33 front and 36 rear refers to car with 4 people and light luggage some on here put less in as in my case its mostly only 2 of us. Therefore i put 31 front and 34 in the rear and it makes for a more comfortable ride. Present :2008 TDV8 HSE
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Vorbis...MD told me the spare has to be 45+ to stop TPMS warning...worked for me at 46psi GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Thanks guys. If I see that warning light once more, I think ill get the 12 bore out and shoot the bloody things |
Get an IID tool...you wont regret it, especially when you switch that B |
Is shotgun damage covered under warranty? |
Ok really fecking unhappy now. Popped to the local filling station to add more air to the spare. Thought I'd check the others again whilst I was at it. Pushed the air hose into the first tyre and the poxy bleeping valve snapped off |
sorry to hear that paul, these metal valves corrode and do snap off very easily... ... - .- -.
Nightmare... feel for you... this problem is actually referred to in the buying guide |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1747 ![]() ![]() ![]() |
Hey Vorbis - Halstead as in Essex..?
Well finally back home now |
