Home > Maintenance & Mods (L322) > Rear wishbones
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Rear wishbones
Simple question... Are they a bitch. Thinking of removing the upper/ lower wishbones on the rear to do bush replacement off the vehicle. This would be done on a ramp . Any one done this and thought... Umm not that bad !!!
2003 v8
Post #270256 11th Jul 2014 8:15am
is this what you mean?
http://www.fullfatrr.com/forum/topic21092.html ... - .- -.
Post #270258 11th Jul 2014 8:23am
DaveK
Sort of, looks like he replacing bushes in situ where as I want to take wishbones off completely and do the work on the bench.
Post #270260 11th Jul 2014 8:32am
Do you mean the wishbones or the subframe bushes.
If you mean the subframe, you have a big job on, remove exhaust, disconnect the rear diff and remove propshaft, disconnect brakes & brake lines, disconnect air suspension and airlines, disconnect FBH pump, then drop the whole lot. Would improve access but (depending on the kit you have) won't make getting the bushes out that much easier Smile
See this other howto for the wishbones:
http://www.fullfatrr.com/forum/viewtopic.p...066a64f102
You have to remove them to replace the bushes, no other way I can see. The upper wishbone bushes are TIGHT! .
Post #270303 11th Jul 2014 2:36pm
DaveK
Bl@@dy Hell... I've bough a hat so that I can take it off to the bloke who has done the job on his drive and recorded it in pictures !! What an epic feat.
Yes, this is the job to which I refer as these are the bushes that are making a noise like two pieces of Styrofoam being rubbed together as the vehicle drives along...... I am now actually crying at the though of undertaking this job.
Post #270318 11th Jul 2014 4:28pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Think i'd be getting a quote from an indie for that....looks like a huge job Big Cry GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #270322 11th Jul 2014 4:50pm
@ DaveK
Worth trying some WD40 or other lubricant first ? Thumbs Up
As I said in the howto, none of the inner wishbone bushes actually needed changing on inspection, this after 10 years on board, so definitely worth trying lube..... .
Post #270324 11th Jul 2014 5:47pm
DaveK
Been soaked in WD40. Then I tried a light spray grease all over them, mate has exactly same problem with his 2004 TD6. The WD must wash off when driving in the wet. Noise is really bad on one side but not so bad on the other. Don't like the idea of only changing bushes on one side though.
Post #270389 12th Jul 2014 9:44am
