Home > Technical (L322) > iid tool and fault finding
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Question for the guys who will know
Just having a play round the iid tool and seeing what faults there are, and to be fare only 2...
in the abs 1 have 5a system deactive temp and 2 8a air suspension system can error.
now both where checked after I cleared the air sus fault I had earlier and did the lock to lock as well.
What in plain English are the 1 and 2 faults?
I will be playing about with the tool ( that's sound so wrong Whistle Laughing ) when I have more time to see where things are.
But a great tool so far though. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #269231 5th Jul 2014 10:49am
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hi
Both systems behaving normally?
Cheers
Post #269977 9th Jul 2014 7:46pm
Welshdragon
Yes thanks Thumbs Up
Since clearing the fault all is good so far, I can only guess why the eas locked out was due to a very poorly track rod end and the steering wheel sensor had a fit.
Both times the steering wheel was at full lock and moving up hill slow speed, mind Im only guessing but 2 track rod ends are on the way.
The iid tool has sorted that annoying bong key in ignition reminder though Thumbs Up
Bit unsure if I should disable the steering wheel retraction. If it dont work.......burn it!
Post #269989 9th Jul 2014 8:41pm
I've always had the can bus error on the EAS, from what I've read it's a common fault but doesn't actually effect anything... mine works fine with it... Pete
Post #270000 9th Jul 2014 8:58pm
PatGAPInnov
Site Sponsor
Correct, those CAN error are a common occurrence and should be left alone unless there`s a real problem with the system.
Post #270001 9th Jul 2014 9:05pm
