Home > In Car Electronics (L322) > 2004 L322 Entertainment unit
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Hi all
Sorry for the possible newbie question. Ive searched and searched and cannot find a reliable anwser.
I have a 2004 FF with a non touch screen. To be fair the sat nav has been pretty reliable even though i have read comments to the cointary.
The TV has never managed to find a station, so im guessing its the old Analogue system and needs upgrading to the newer digital? I have an "aerial" built into the Tax disc holder, but cannot seem to find out what its for.
The telephone function seems to do nothing, so im guessing this is an option that wasnt used, and i cannot locate any connectors etc.
A reversing camera would be awesome.
I consider the screen to look a bit dated in colour and the old 2004 satnav disc is a bit out of date. Im pretty handy with wiring and soldering etc, so looking to do an update on the cheapish (as ive already poured money into the car)
Ive been qouted £199 for a TV tuner, £99 reverse cam and £39 for Video in motion. Then i guess the BMW Mk4 Satnav unit and a later disc is required?
Does that sound sensible, or is there a common DIY system that you guys do?
Cheers in advance
Tel Accept, some days your the pigeon, some days your the statue!
Post #269866 9th Jul 2014 10:08am
i'd be tempted to get an after market head unit that has all those things integrated...some on the forum have done this upgrade .. ... - .- -.
Post #269879 9th Jul 2014 10:38am
It's all been done, and is all covered on the ICE section of the forum somewhere, but as stan says, a single solution may be the way to go, unless you like to tinker... Smile .
Post #269938 9th Jul 2014 2:19pm
mjdronfield
Not sure why the telephone function is on the menu as it should not appear unless it has been found on the ibus.
Do you have a phone in the centre armrest ?
I put a hybrid TV unit in from an X5 which is a straight swap, and then fitted a BMW ulf so that the system paired with my mobile phone when I got in the car, again, from a later BMW.
I bought a mk4 sat nav with 2010 map disk from a mate who upgraded it in his E39 M5, and I have also done the BM54 stage 2 amp upgrade that Baris on this forum does.
I'm well happy with the setup as it looks standard, nothing visually has changed.......
As others have said though, you can rip it all out and fit a unit from China..........or even a car PC....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #269947 9th Jul 2014 5:07pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
I've put in the digital tv system with reverse camera and the price looks similar to what you paid, so I reckon I know who you are talking to. It was an easy fit - probably took me a couple of hours including wiring the rear camera as it was all relatively plug and play. I have the rear seat entertainment with DVD changer so I complicated my install by routing it all to ensure each rear screen could choose TV or DVD independently of what the front screen was set to (if it was on). TV In motion came with it but I deactivated it. If you are handy with wiring then its an easy install and for the one question I had subsequently they responded with advice within an hour.
I did also upgrade the Satnav to the BMW Mk4 DVD sourcing a unit on Ebay - 5 minute job and I still managed to sell the Mk3 unit on Ebay for not much less than the Mk4 cost me! I didn't do that at the same time so you can upgrade the TV without doing the satnav - for when the bank account recovers. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #269949 9th Jul 2014 5:18pm
