![]() | Home > Maintenance & Mods (L322) > Battery Trouble (again) |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 ![]() ![]() ![]() |
Right, yet again I couldn't start the RR after 3 days not being started. Going to do more checks for a parasitic draw but in the interim I have decided to change the FSR as this seems to be what most recommend.
I understand what you are saying and I agree completely. And I do intend to find the parasitic drain although last time I did this I could not find a drain, but I may have missed something.
Yes that makes perfect sense, effectively you are ensuring that you always have a fully charged battery with you that you can use as a "battery pack" should the need arise due to a flat car battery. |
The jump leads I have are very heavy duty. I think they are from the haulage industry so easily up to the job.
Do you reckon two batteries (without the voltage sensitive relay) would discharge each other in ping pong fashion until they are both flat, or only in as much to equalise the charge between the two ? .
The only problem I could foresee is if the two batteries were in a different condition to each other eg one was older and not able to fully hold a charge to the level of the newer one. IMO it would be better to start with two new batteries and let them grow old gracefully together. Generally two batteries connected in parallel will be fine even batteries of different capacities.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8377 ![]() ![]() ![]() |
There is enough room under the carpets, there is a rebate the entire length of the sill that has the space for an additional battery cable, I was exploring this when I had all the inside out, there are several routes it could take... Pete I now have permission from the boss to use Y.O.L.O. Enjoy life __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Thank you Pete, I will take a look. |
