Home > General (L405) > Gear change issues |
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 718 |
My gear changes are much smoother than they were in my 2010 SC as they should be given the switch to an 8 speed box. I use the paddles mainly for downshifts to give more engine braking on steep hills and it seems to be very smooth. Only thing I have noticed is the final shift down when coming to rest was a bit rough but that seems to have gone now I have done a few more miles. Sounds like you need to have it looked at. |
5th Jul 2014 4:27pm |
Flugplatz Member Since: 27 Feb 2014 Location: Cornwall Posts: 75 |
Thanks, 5.0. I also use the paddles to down-shift for engine-braking (feels like there is surprisingly little engine braking in the petrol car, btw).
7th Jul 2014 6:46am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
I think you may have it there because the engine is meant to blip the throttle to mach the revs on the way down the box. 2008 MY Supercharged
7th Jul 2014 7:45am |
Axle, thanks. It's precisely that rev-matching throttle blip that seems to be missing.... That is, in the car as-is, the gearbox down-shifts without a smoothing 'heal and toe' blip on the gas (youngsters, ask a grown up...).
7th Jul 2014 8:04am |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
I don't understand why people leave it to the car to do the blip. If you change down keep your constant throttle position and the revs will match almost perfectly, something that works in na/supercharged manuals too. The ecu will adjust the throttle plate so you don't blow the car up.
7th Jul 2014 10:03am |
TASP, thanks (hope you don't mind the abbreviation )
7th Jul 2014 11:51am |
Aeroresh Member Since: 31 May 2008 Location: North Wales Posts: 137 |
This isnt official but this fix has worked on some other cars notably bmw and mercedes (and my range rover I think!) with fly by wire throttle.
7th Jul 2014 4:31pm |
Aeroresh,
7th Jul 2014 4:36pm |
The gearbox adaption reset is well known, but I've never had much luck with it. The iidtool for the l322 does a better job. I think it might be your fancy new 8 speed gearbox being too clever for itself. I hope it does go away though, I had similar issues and they just vanished, but my car isn't new so I wasn't too annoyed.
7th Jul 2014 6:58pm |
