Home > Technical (L322) > Engine system failure |
1959terry Member Since: 28 Apr 2014 Location: London Posts: 128 |
I was getting the same fault alarm when I started from cold. I took it to the garage and they put it on the computer which showed code P132E turbo boost control B performance. They cleared the fault and it has only come back once in the last month. When I googled the fault code mine appears to be the turbo actuator which was sticking and apparently they can be sprayed with wd40 or similar to help.
5th Jul 2014 4:44pm |
Turbo related is my guess so above is relevant |
5th Jul 2014 7:06pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1751 |
Turbo actuator sticking, or a split turbo hose. Both very common |
6th Jul 2014 7:22am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
Any black smoke ?
6th Jul 2014 7:54am |
Harris Member Since: 02 Apr 2013 Location: Northants Posts: 155 |
No black smoke and it has not re occurred so I think sticking actuator, I don't think it had been over 3500rpm much |
13th Jul 2014 8:23am |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 |
Being someone who already had both of them....
14th Jul 2014 11:28am |
