Home > Technical (L322) > Halogen to xenon
rejo
Halogen to xenon
Has anyone ever changed the halogen headlight unit (fitted to some hse) to a xenon unit fitted on the vogue models.
If so was it plug and play or a bit more involved.
Cheers
Post #268217 30th Jun 2014 6:00pm
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
I would love to know as well.
The lights are ok,but when I'm out bush I need something better.
I do have a pair of spotties,but there's alot of frigging around the mount them as I have the A bar and they are a very tight fit if I put them in.
cheers
Post #268284 30th Jun 2014 11:06pm
mjdronfield
I am pretty sure this has been discussed a few times. Not sure if we got to a definitive answer though.
Can't see why you can't swop them, but you'd need ballasts and resistors and connectors etc etc.....
http://www.fullfatrr.com/forum/topic25437.html?highlight=xenon
That was little cubs original thread.
This may help ;
http://www.fullfatrr.com/forum/topic11082.html?highlight=xenon
http://www.fullfatrr.com/forum/topic4883.html?highlight=xenon
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #268397 1st Jul 2014 4:59pm
rejo
Thanks everyone for the replies.
Just to clarify, at the moment the high and low beams are both halogen, as fitted to some hse models.
What I would like to do is change this to a xenon unit from the vogue model.
As there isn't a projector type lens in the halogen headlamp I will have to buy a complete headlamp unit from a vogue model and not just drop in a xenon kit from ebay.
All that make sense !!!
As self levelling is standard and headlamp wash wipe is fitted it meets all the requirements for the annual control so in theory its just a case of dropping in a complete xenon headlight unit.
But after some research it seams that the xenon unit has 8 wires running to it where as the halogen unit has 4.
If anyone has a diagram what the 8 wires are for that would make things a lot easier.
Cheers
Post #268410 1st Jul 2014 5:27pm
rejo
Cheers
Post #268411 1st Jul 2014 5:29pm
rejo
sorry double post, terrible internet !!!!
Post #268413 1st Jul 2014 5:35pm
I don't have a wiring diagram for the Xenon lights but I think the wires are as follows,
Main Beam
Dipped beam / Main beam Xenon
Dipped beam shutter
Earth
Headlight Leveling 4 wires.
Post #268414 1st Jul 2014 5:37pm
rejo
Any idea of colours ???
Post #268416 1st Jul 2014 5:43pm
Got to go out, will post them later tonight. Thumbs Up
Post #268417 1st Jul 2014 5:44pm
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
an alternative to putting in original LR b-xenons is to get yourself aftermarket bi-xenon projectors and hid xenon kit.
I've done that on my car (high beams) and what a difference it makes.
Connection is as easy as pie - connect low beams to bulb and high beams to wires that comes with the projectors and Voila! Bobs your uncle.
Now if I were you I would do both lights with these bi-xenons - connection is as above, just use the wires for low beams for both bulbs and high beams to the wires of the projector.
Btw with if you fit the projectors, you don't have to buy other headlamps
Post #268421 1st Jul 2014 6:28pm
These are the colours and diagrams for the two headlights for the all halogen set-up.
There are only 7 wires to each headlight , if you need a separate wire for the xenon shutter this could be operated of the halogen main beam. ie when main beam is selected it would also operate the Xenon shutter into the Main beam position on the Xenon lamp.
If the images aren't clear enough, pm me your email address and I will send you the original wiring diagrams for your car. Thumbs Up
For some reason wiring diagrams don't upload to the original quality.
Post #268449 1st Jul 2014 8:34pm
[for some reason - images - quality]
forum resizes/transmogrifies them Twisted Evil
but does seem to specifically affect wiring diagrams Confused
Better to upload as a pdf ? .
Post #268453 1st Jul 2014 8:39pm
vnitos
nicedayforit: Thumbs Up hundred percent correct. I used the wiring for the high beams for the shutters to work
Post #268496 2nd Jul 2014 5:08am
