Home > Maintenance & Mods (L322) > Valve seats leaking oil?
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Hi all,
I keep getting a puff of blue smoke when I start up my SC, which I think is oil leaking back into the combustion chambers when the engine is shut off? Once the engine is started it doesn't blow anymore smoke and runs fine. All I want to know is the following really?
1. Apart from the current wear, is this going to damage my engine further?
2. How much does this cost to repair? Is it just seals and lots of labour taking the head off or is it a new head?
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #268272 30th Jun 2014 10:49pm
The valve seats can't leak oil, do you mean the guides?
Post #268273 30th Jun 2014 11:13pm
TheAllSeeingPie
Valve stem seals I think is what I meant? The tiny little o-rings that should stop oil leaking into the valves?
Post #268275 30th Jun 2014 11:19pm
Ok. Thumbs Up
Think you can do them without taking the head off, but someone knowledgeable will probably come along soon and give a proper answer.
Post #268276 30th Jun 2014 11:21pm
Are you running on LPG?
Post #268282 30th Jun 2014 11:53pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
KurtVerbose wrote:
Ok. Thumbs Up
Can't do the valve stem seals without taking the head(s) off, compressing the valve springs, removing the collets and removing the valves.
Steve.
Post #268283 30th Jun 2014 11:58pm
mpirie
There was an old mechanics trick of removing the spark plug and feeding sone narrow rope into the combustion chamber once the piston was down at the lowest point, then keep turning the engine until the rope compressed in the chamber and would stop the valves dropping in once the valve spring was compressed and the collets removed......giving you access to the valve stem oil seals once the spring was removed.
Done it on a few Ford Pinto's but never a V8........the theory should hold though!
Post #268292 1st Jul 2014 1:41am
TheAllSeeingPie
Nope, no LPG and the engines done 105k miles.
Post #268312 1st Jul 2014 8:35am
