![]() | Home > Maintenance & Mods (L322) > L322 Rear Mud Shields replacement |
Semperfidlas Member Since: 27 Jul 2013 Location: Worksop Posts: 59 ![]() ![]() ![]() |
Hi
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Why are you having to replace these? if it is because of removing the disk without slackening the adjuster, there is a thread on here somewhere showing how to repair the broken location pins in situ, saving you from a very big (and expensive) job. |
The back plate has rusted out round the shoe pins locating hole nothing more I've read joe 90 post about doing front ones in situ and he suggests the rear could be done the same way however I'm not so sure because of the backplates being an integral part of the hand brake system.
I believe the handbrake parts are fixed to more solid metal than the dustguard! My repair/bodge on the front dustguards won't help with the shoe pin holes, but I suppose a similar approach might work if you find some suitable washers and bend then to fit the recess for the shoe pins to nestle in.
They are a nightmare!!! We have tried cutting a new one in half and welding it back together (which really didn't work at all well) i would suggest maybe cutting the handbrake recesses out and welding just them in?
If just the shoe pin holes are the problem, perhaps make up some "inserts" and get them welded in ? .
