![]() | Home > Technical (L322) > Prog Trans Failsafe as soon as key in ignition |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
if you fancy a read,
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
I used to get this on my 2003 TD6 too. The regular "bong of doom" used to drive me mad!
jackvine Member Since: 28 Jun 2014 Location: London Posts: 6 ![]() ![]() ![]() |
Ok thanks, TSM definitely seem like a possibility, I did try putting it in low range earlier and nothing happened !
Nice approach SKOT |
Well looks like battery is the Issue, Halford a year ago has fitted a Bosch S4 85AH, I left it on charge for 24Hour and still not fully charged!
Batteries are a funny old thing - Pretty fragile.
Well I have a new Varta battery to fit, but not had a chance yet, but measured the Bosch after a run and it was sitting at 12.2V so Im guessing its on it way out, as the alternator charging voltage is 14V.
Watch these first............
Yeah thanks seen them already, I sprayed the bolts with Plusgas tonight so I'm hoping it will only take 10 mins to remove tomorrow. |
OK fitted new battery and removed motor.
