![]() | Home > Maintenance & Mods (L322) > S/C Gearbox slipping |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Have you had it plugged in and the fault codes read at all? Might be worth a shot to see if there's an electrical fault or something easily traced.
MrSkill Member Since: 08 Nov 2012 Location: England Posts: 62 ![]() ![]() |
I had what's sounds a very similar problem, was convinced it must be serious but found this and completely sorted;
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 ![]() ![]() ![]() |
Thanks guys, there were no gearbox fault codes found last week so sadly not easily traced, although I am liking the suggestion that some WD40 may solve it.
With suspension up to highest you can get underneath quite easily. I think it's on the drivers side but if you can get someone to move the gear changer whole you are underneath you can't miss it. Give it a good few squirts and go up and down the gears.
Yep I had this a year ago , went nuts with some PTFE spray and all was good again |
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 ![]() ![]() |
+1, usually does the trick.
Many thanks guys, all sorted and very obvious once you are under there and all for the price of a few squirts of WD40!
