![]() | Home > Maintenance & Mods (L322) > Broken locking wheel nut |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
Hi Bigbangman,
Bigbangman Member Since: 10 Jun 2010 Location: Worcestershire Posts: 51 ![]() ![]() ![]() |
Hi Delamo,
Your eBay link doesn't seem to be working Bigbangman so I can't see what yours are like...
DeltaC Member Since: 22 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
The extractors you are refering to are probably made by Irwin - Great tools. If you can get the rotating cap off with a chisel, they should go on no problem. They are easier to use with an impact wrench though as that allows you to push, while the wrench does the turning.
Indeed DeltaC - it was infact your information (and dan_uk_1984) that helped me when I had this very problem with my nuts a few months ago! - Thank you |
Hi, thanks for the replies:
No problem Bigbangman - hope my experience helps you out |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
I looked at a wheel nut remover socket device in Halfords. if I remember rightly, I think they use a reverse thread and somehow as they go on they crush the outer spinning cover against the real internal head, then you just use a normal socket set to unscrew them off. Obviously, you then need to buy a new set of locking wheel nuts. Kit is £17 - Link below...
Steve,
Hi DeltaC, thanks for clarifying. |
