![]() | Home > Maintenance & Mods (L322) > FFRR TD6 '02 Second Battery Fit Out |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Had to wait a long time to do this, until I felt it was about time to replace my existing battery a Varta Silver 110ah/920 crank. Replaced with exactly the same model battery up front, leaving me with the opportunity to fit the old one in below the rear right cubby.
I had already made up the leads a long time ago, fitting a 60amp fuse to the red cable, and quick release fittings. A quick clean up of the old battery, then took to it with my trusty Homesbase tenon saw, removing the "feet" around all four edges to ensure I could get it in.
Released the thick cable run from its clips and lifted it out of the well, then removed the two captive nuts in the cubby floor. Carried out a bit of rust prevention whilst at it. ![]() ![]() Dropped the battery into place, snug as a bug right to left, with @ an inch of play fore and aft. The thick wadge of cables slipped neatly around the left edge of the battery.
Earth was found on the other side of the spare wheel compartment, I used the redundant cable clips from the cubby to secure it, and live was fixed to the live fixing to the right of the fuses (on the rear fuse box). ![]()
Connected up the front battery first as per normal,
then fitted live then earth to the rear battery.
The cubby support panel (black) nearly almost fits back as normal, just slightly in contact with the live terminal cover, but the two carpeted covers went back into place OK.
All that remains is to put a suitably worded warning notice on the front battery. "This vehicle is fitted with two batteries. Do not attempt to start vehicle when the front battery is disconnected!" Hoping, beyond hope, that this will see off any "HDC Inactive" bongs this coming winter! Any suggestions on improving this setup most welcome. I don't need to power additional devices either inside or outside the vehicle. . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Lovely tidy job that....I get worried in cold months after using the FBH if there will still enough juice for starting so might look at that, but then I'll have to look as to where to put the detachable tow ball....FF ownership sure is "fun" |
Yeah, exactly what was needed from the factory TBH. I think the only mode I would make to that is to add an isolator switch to save having to lift trim if you wanted to disconnect it. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
great job Tim [as usual |
@ iphs
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 ![]() ![]() ![]() |
OK Joe,
@iphs ( You may wish to search this and other FFRR forums regarding 2nd batteries to get more qualified answers to your questions)
Thanks Joe, I will do some research. |
Hi Joe,
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
So Steve, would it be possible for forum members to add a second battery and have (like a Transit van) one battery purely for starting and battery two for everything else? |
Theoretically that would not be too hard to do. In practice I see a couple of problems - #1 being that with all the electronics, you'll need to have everything powered at once when starting. If you then imagine a flat starter battery and a healthy secondary battery, you are going to be running much more current through the wiring from the rear battery than it can handle, and |
Thanks for additional advice/input SteveMfr.
I am not sure which way to go with this Mod at the moment. |
To get the best of both worlds it seems a modulator for general use with a bypass switch when you need both batteries to work together ?
