Home > Maintenance & Mods (L322) > List of 4.2SC Technical Service Bulletins?
pld118
Found the below list and link which says these are TSB for 2007 Supercharged. Don't know if any good to anyone to be aware of in the event of...
Technical Service Bulletin Titles for 2007 Land Rover Range Rover (LM) V8-4.2L SC:
APRIL 2011 A/C - Rear Defogger Grid Repair
FEBRUARY 2011 Heating/A/C - Whistle Noise From A/C Recirculation Flap
JANUARY 2011 Body - Front/Rear Door Window Regulator Diagnostics
MAY 2010 Tire Monitor System - Preventing Valve Stem Damage
APRIL 2010 Suspension - 'Suspension System Inactive' Message
JANUARY 2010 Suspension - Software Update After Compressor Replace
SEPTEMBER 2009 Entertaiment System - DVD's Skip/Won't Play
SEPTEMBER 2009 Steering - Steering Column Tilt Malfunction
JULY 2009 Suspension - Will Not Lower/DTC C1A13-64 Stored
MAY 2009 Suspension - Revised Air Suspension Calibration
APRIL 2009 Engine - Chirp Noise On Cold Engine Start Up
FEBRUARY 2009 Drivetrain - DTC P186D In Differential Control Module
JANUARY 2009 Engine - Aluminum Component Thread Repair
SEPTEMBER 2008 Cooling System - Revised Radiator Removal/Replacement
AUGUST 2008 A/C - Heated/Cooled Seat Fan Noise/Fan Inoperative
JULY 2008 Satellite Radio - Loses Station Presets
JULY 2008 Engine - Main Bearing Carrier Leaks
MAY 2008 Cooling System - Low Coolant Level Switch Availability
MAY 2008 Radio/CD - Audio Cuts Out CD Icon Grayed Out
MAY 2008 Cell Phone - Phonebook Over Bluetooth(R) Feature
APRIL 2008 Steering - Squeak From Steering Gear
MARCH 2008 Navigation - Screen Starts Up Shuts Down Erratically
FEBRUARY 2008 Cooling System - Revised Pressure Testing Procedure
JANUARY 2008 Drivetrain - Clonk Noise After Throttle Apply/Release
OCTOBER 2007 Suspension - Vibration/Droan at 55-75 MPH
AUGUST 2007 Entertainment System - DVD System Diagnosis
JULY 2007 Computers/Controls - IDS Vehicle Reset Application
MAY 2007 Cooling System - Engine Overheating Condition
APRIL 2007 Body - Paint Discoloration Under Protective Wrap
MARCH 2007 Audio System - No or Intermittent Audio Sound
FEBRUARY 2007 Engine Controls - Screeching Noise From ECM Housing
DECEMBER 2006 Steering/Suspension - Droaning Noise at 55-75 MPH
DECEMBER 2006 ABS - Wheel Speed Sensor Fault Diagnosis
DECEMBER 2006 Brakes - ABS Module CAN Fault Diagnostics
OCTOBER 2006 Entertainment System - DVD Player Disc 1 Locked Out
SEPTEMBER 2006 Audio System - Speaker Vibration/Rattle Noise Diagnosis
JUNE 2006 Body - Doors Hard To Open From Inside/Outside
http://www.tsbdata.com/tsb/2007-land-rover...2l-sc.html
Post #266374 20th Jun 2014 3:36am
jonbaobao
2007 Range Rover Supercharged 4.2 SC V8 Java Black
Thank you for sharing!
Post #403424 5th Sep 2016 1:42pm
georgedb
South Africa 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Indeed. Thanks a stack.
Does anyone know the cause and a fix for bulletin - "APRIL 2009 Engine - Chirp Noise On Cold Engine Start Up"?
Wink
Post #403447 5th Sep 2016 3:14pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Much appreciated Thumbs Up
Thank you
Peter
Post #403450 5th Sep 2016 3:22pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
A current "favourite" of mine; supercharger coolant pump, seems to be missing although that may be for earlier models only. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #403460 5th Sep 2016 4:45pm
