![]() | Home > In Car Electronics (L322) > Bluetooth problems |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
in my MY2006 SC I get in and connect my phone to the Bluetooth. It doesn't download or show the phone book so when someone calls unless I can see my phone screen I just get a phone number and do not know who is calling. If I turn the car off and use it again a few minutes later I have to connect and pair again to the car and I have to do this every time.
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
I forgot about this.
That is the most annoying thing to be honest, any idea on cost for the upgrade as there aren't any prices on the website.
Reading the website says that the constant pairing stops and the phone book is downloaded and to be fair for £65 it seems a very good deal indeed.
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
I have a Bluetooth upgrade from Wiggs/bluetoothexchange - mine stays paired and uploads the phone book
Is it worse since the upgrade or the same? Alex
There is a better upgrade to the standard firmware flash upgrade that can be done easily enough as I have done with the later units. Requires two cables being cut into and job done.
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
Mine was fine after the update and clear to hear both ways. The problem came some weeks after the upgrade so I don't believe the two are connected. There is a difference between knowing your sh!t and knowing you're sh!t
Alex, sound quality was the same before and after the upgrade - the RR is just not as good as the Merc
I'll have to find the link later but for your fault have you tried replacing the mic for the later one?
I got a new microphone from Dan but sounds just the same. I even uninstalled my Pure DAB in case it was interference and unplugged the phone charger and radar etc... but no difference. Seemed to go bad overnight. There is a difference between knowing your sh!t and knowing you're sh!t
Have you checked for water ingress in the rear compartment? Could be rusty pins on the connector/module... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
Got my unit today after not ordering it as I was busy so will be fitting tonight or tomorrow night and trying it out. Went on holiday in the car in August and it was a pain having to pair the phone every time I got in and out of the car.
