Home > Technical (L322) > Heated Mirrors
nbunney
Heated Mirrors
Should my TDV8 have heated wing mirrors?
If so how do they work?
Carn't find any ref. to having / using them in the handbook
Post #9896 23rd Dec 2009 9:27am
itguy
2006 Range Rover Vogue Td6 Cairns Blue
I'd be amazed if it hasen't.
they just work automatically. FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps
Post #9898 23rd Dec 2009 10:29am
But like the heated washer jets, what starts them off?
Is it anything to do with having the lights on? I know it sounds weird but they can't be automatic or based on temperature.
I've seen them working on FFRR's, slight smoke lifting from the glass as moisture is evaporated. Discovery 4 HSE
Post #9903 23rd Dec 2009 1:10pm
itguy
RAVE states that the wing mirrors come on automatically when outside temp is low (below 15c I think) but if you switch on the rear window heater this also overrides them on.
Also, I've noticed that the heating in the mirrors isn't too strong (certainly no audi!) But they do work just time.
Photochromatic (auto dimming) wing mirrors are also thicker so they take longer to heat. FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps
Post #9911 23rd Dec 2009 4:51pm
ukrangie
Don't know how it works. Having just replaced my mirror, I can confirm that the mirror does have heating tracks at the back of the glass which are powered by two cables.
Post #9917 23rd Dec 2009 6:21pm
Stoich
From Workshop manual
Mirror Heating
Mirror heating on the driver's and front passenger's doors is controlled by the respective door modules.
The BCU receives the outside temperature value via the K-bus. This outside temperature value is converted to a
switch on-time percentage according to the following table and then transmitted via the P-bus to the two door
modules. Mirror heating is active with the ignition at position II.
If the wiper is switched on, the switch on-time percentage is raised in accordance with the following table.... If you like it, who cares what other people think
Post #9935 24th Dec 2009 9:22am
nbunney
Cheers Stoich
I've sent you have PM Thumbs Up
Post #9944 24th Dec 2009 3:49pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
As stated already, I can confirm my also come on when I press the rear window heater/demister button. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #9991 27th Dec 2009 12:54am
Captain Slog
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Does anyone know the cost of a left hand (passenger side) replacement heated mirror glass? or does anyone know the Land Rover part number for this glass?
Car is an early 2005 Vogue TD6
_________________
Currrent: 2005 FF Range Rover L322 Vogue TD6
Gone: 1999 Range Rover P38 HSE TD6
Gone: 1985 Land Rover 90 SWB diesel
Post #26599 27th Aug 2010 4:09pm
At a dealer you will pay £150. Shocked Discovery 4 HSE
Post #26611 27th Aug 2010 6:53pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
And if replacing it is as difficult as it was on the RRS then it's something best left to the dealer, if only so they pay for all the mirrors they break trying to replace yours! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #26614 27th Aug 2010 7:41pm
Captain Slog
Anyone know the part number (heated)
_________________
Post #26629 28th Aug 2010 5:49am
Can't remember the part no's but non chromatic autodipping mirrors are between £70 and £90 and the auto dipping are £150 . 2008 MY Supercharged
Post #26631 28th Aug 2010 7:37am
Discocuzzy
I need the whole unit......£595 plus vat from Landrover Shocked Shocked
Post #26694 29th Aug 2010 11:24am
Tim in Scotland
Try Lookers Park Royal Parts Dept and give them your forum name and your real name........................ usually gets a little bit of discount Cool 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #26705 29th Aug 2010 12:11pm
