Home > For Sale & Wanted > [Wanted] Wanted: Tow Bar
dhallworth
Looking for a tow bar for a 2006 Supercharged FF.
Need the armature, and towing electrics. Have got a drop plate but if it's for sale with the removable part as well I'd be tempted to take the lot Smile
Thanks
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #265466 14th Jun 2014 8:31pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
D,
Pm sent. Thumbs Up [/i]
Post #265481 14th Jun 2014 9:45pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Apologies for hijacking thread but once the OP is sorted, I am in the market for a complete towbar/electrics assembly too.
Later type L322. Incidentally when do the towbar armatures change over? 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #265492 15th Jun 2014 6:16am
nbunney
PF Jones in Manchester are cheap enough for OEM kit Thumbs Up
Post #265580 15th Jun 2014 6:46pm
160dmb
You're right thank you.
Now what are they opinions for farmers hitch or swan neck?
Am I right in thinking the armature is the same for both, you just choose which ball type you prefer?
Any advice? 2016 (L405) Autobiography in Black with Ivory - for ULEZ
Post #265599 15th Jun 2014 8:23pm
Yes - armature is the same
Swan neck has the mounting bolted to the armature, then the remainder of the swan neck sits in the under floor compartment next to the spare.
Farmers can either be bolted, or use a pin - I use a pin, so it quick releases easily and leaves less visible than the swan neck - however, it doesn't fit away nicely in the boot.
If you've ever seen the US 2" receiver system, it's basically the same, except it used 50mm rather than 2"
Post #265602 15th Jun 2014 8:34pm
sako243
In my opinion the farmers hitch is the more useful:
1. You can adjust the height - perhaps not an issue but I tow a variety of trailers, one triple axle that sits quite high
2. You can bolt a bike-rack to it
3. Cheaper
I will admit that the swan neck potentially looks a bit nicer / less clunky but given the farmers is more practical and noticeably cheaper I'd (and have) gone for that one. In fact ended up with two now...
Post #265618 15th Jun 2014 9:35pm
160dmb
I might be tempted to agree and buy the farmer hitch as my old Brian James 4 wheel trailer seemed to need some adjustment on the back of my Cayenne, so if I bought a new one I'd probably go farmers hitch but if a used swan neck came at a decent price I'd have that because of the nicer storage solution.
How tricky is it to attach a farmers hitch, looks like a lay under the car to attach piece of kit from what I have seen before. 2016 (L405) Autobiography in Black with Ivory - for ULEZ
Post #265745 16th Jun 2014 5:25pm
sako243
Slot hitch into receiver. Insert pin, insert R clip. Done. Simpler than a swan hitch.
Post #265752 16th Jun 2014 5:45pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Agreed, we have the farmers hitch, you don't have to get under the FF to install it, and it takes all of 10 seconds. Thumbs Up
I also discovered that you CAN use an early (02-05) armature on a later (06 - 12) car Very Happy (involves cutting right angle brackets for exhaust mountings off the 2 'crash bars' which you remove as part of the installation) but you CAN'T use the later armature on the earlier car.
(Westfalia confirmed that this is acceptable Thumbs Up , we bought a tow bar described as the later type from e-bay, but found when we came to fit it that it was in fact the earlier one. 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #266739 22nd Jun 2014 3:26pm
