Home > Technical (L322) > New user: GEARBOX drama.... No one can help up to now.... |
Winchester101 Member Since: 13 Jun 2013 Location: Essex Posts: 236 |
I wonder if they actually changed it : 1994 softail full stars n stripes custom harley davidson |
13th Jun 2014 6:01pm |
I had that on my 2007 TDV8. Exactly as you describe. It was a faulty torque converter causing it but I had all the fluid changed at the same time. Was fine after that. |
13th Jun 2014 6:24pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1194 |
Ask Neil smith cannock and tell him symptoms and tell him Scott told you to ask, his number is 01543 505599 _____________________________________________________
13th Jun 2014 9:58pm |
Did you get the codes read ??? It almost sounds like the problem I had with my 4.2 and that turned out to be a problem with one of the coils. However that was 3-4 shift problem. At the time I replaced the complete set of coils (not too expensive) and that solved all the problems. I'm sure it won't only affect the 3-4 shift (my 5-6 also sometimes gave me issues at the time) so it would be a good option to check that first.
14th Jun 2014 11:46am |
RichieLloyd Member Since: 13 Jun 2014 Location: Liverpool Posts: 11 |
Thanks all, I will take these back to the guy who did the gearbo (Aintree Automatic Transmissions), he seems totally genuine and was recommended by a lot of people, he has been in the business 30 yrs and mainly does the xf gbox.
14th Jun 2014 1:58pm |
The issue with the coils is not well documented it seems. The ZF box is in a lot of cars (different brands) including the big boys like Audi/BMW/Merc/VW/Ford Oz etc. These boxes, the 6 HP 26, are virtually bullet proof and the gearbox outfit in the Netherlands (they have also been around for years and years and only do gearboxes) couldn't help me diagnosing either, because so few go wrong. They did say that the coils is one of the first items they replace on these boxes if they come in with problems.
14th Jun 2014 2:19pm |
Ebejema, thanks very much, I will act upon your posts this week n let you. Thanks all
14th Jun 2014 10:32pm |
I hope it is of use to you because that would be an easy fix !!! If the guy just replaced the Mechatronic but not the coils for example, that would explain why you are having issues still, if I'm right about the coils being the problem of course
15th Jun 2014 8:47am |
Ebajema, when you say coils, do you mean electrical coils, as in solenoids? I'm intrigued now because if so it might well explain an issue that one of the D3 chaps has.
15th Jun 2014 9:01am |
Hi Dom, yes, I keep saying coils but indeed the solenoids are the problem. Going through my post may help the D3 guy, at least give him some info on what the issue was. MY 2010 5.0 SC Galway green and sand interior!!
15th Jun 2014 9:03am |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
Must admit I was confused with references to coils. |
15th Jun 2014 11:57am |
SORRY MY 2010 5.0 SC Galway green and sand interior!!
15th Jun 2014 12:49pm |
Hi all again,
16th Jun 2014 2:26pm |
Mechatron that was meant to be, god damn predictive text |
16th Jun 2014 2:30pm |
