![]() | Home > Technical (L322) > Gearbox overheated- contemplating rebuild |
Winchester101 Member Since: 13 Jun 2013 Location: Essex Posts: 236 ![]() ![]() ![]() |
Not sure where you are in London but there is a great guy that repairs or rebuilds auto boxes on canvy island
Bagus Member Since: 14 Apr 2014 Location: London Posts: 202 ![]() ![]() ![]() |
I had a similar problem however I received the "transmission overheating" error message on the dash. My gearbox was replaced a couple of years ago and radiator etc replaced a year or 2 go so thought unlikely for those to go again.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
Yes, certainly worth testing the resistance of the fluid temperature sensor with a multimeter before spending any money.
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 ![]() ![]() ![]() |
See my previous post at bottom of page,I did option one originally and was a complete waste of money unfortunately.I'm currently over 121k and no problems with gearbox or TC since... |
jumbocar Member Since: 08 Jul 2013 Location: London Posts: 22 ![]() ![]() |
Hi
hy
There is a nice howto on here by Saint.v8 on changing the transmission oil cooler for a V8, reporting the same symptoms as the OP.
Okay, you've convinced me.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
my cars previous owner (2002 v8 petrol) had autobox overheat, changed cooler rad, and then the box itself, still got hot, it was a 'collapsed feed pipe' (transmission cooler pipe from box to rad.)flexible part internally blocked. it had strangled itself. expensive fault finding. (for him) |
Ouch, what a nightmare
remember, when you change your gearbox oil, you are only 'changing' the bit in the gearbox, you cant drain what is in the torque converter. (a few more litres) so, if you are doing a 'best' job, you might want to change it soon after the first time. it will have mixed with the old and sort of given you a better longevity. you could perhaps remove each end of the trans pipes, and perhaps attach some rubber tube, and pour fluid through to test their flow.
Thanks... I'll do the initial flush plus cooler replacement, drive it for a week and see if it cures the overheating...
