Home > Maintenance & Mods (L322) > How long should rear calipers last? |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 220 |
Mine rears were originals and I replaced them at 170k, probably 10k tool late. The offside was sticking badly for some time although I did not realise it. I replaced them with all the bolts, clips and flexible hoses on both sides and all is now much better. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
11th Jun 2014 10:34am |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
On my previous Td6 - with TRW calipers - the ROS stuck at 6yrs / 80k ish.
11th Jun 2014 10:38am |
Thanks for the replies.
11th Jun 2014 2:06pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
I think it's possible calipers seize because the brake pads seize first due to corrosion. The pistons then seize because of lack of any movement.
11th Jun 2014 2:48pm |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
Both have been done on mine. Nearside rear in March this year at 71k and the offside at 59k in December 2012.
11th Jun 2014 3:07pm |
^^ My replacement refurbished calipers are identical TRW to the original - I'm certainly not qualified to recommend an alternative !
11th Jun 2014 3:11pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7893 |
I needed new discs and pads, so replaced the rear calipers anyway.
11th Jun 2014 8:49pm |
Thanks, did you exchange for TRW calipers and where do you exchange them please?
12th Jun 2014 6:47am |
