Home > Maintenance & Mods (L322) > third brake light
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
third brake light
hi all
help needed
I have just noticed that i have a bulb gone in the third brake light is this a a simple bulb change or is it a unit replacement
cheers all Surprised 02 Range Rover HSE Zambezie silver 4.4
Post #26405 25th Aug 2010 7:24pm
afaik its a led strip so the whole thing needs replacing...also i didnt know that the two rear side breaklights are leds as well [according to the manual]... ... - .- -.
Post #26428 26th Aug 2010 8:37am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
L322 was one of the first cars to use LEDs for the rear lights Scarey..................... one of the worldbeating things that LR pioneered like HDC/TR etc Mr. Green and like HDC one of the things BMW claimed they owned the patents on when they sold LR to Ford and took with them to use on the X5! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #26433 26th Aug 2010 8:54am
interesting tim, so if one fails is it an expensive job... ... - .- -.
Post #26434 26th Aug 2010 8:58am
Tim in Scotland
How long have you been owning Land Rovers scarey?....................................... Haven't you noticed that almost anything that has the LR oval stamped on it is vastly overpriced. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #26435 26th Aug 2010 9:03am
about three weeks tim.....but i get your point. ... - .- -.
Post #26436 26th Aug 2010 9:10am
Martin
Site Admin
Unusual that the whole thing's stopped working, might be worth checking the wiring to it if you're handy with a multimeter?
Otherwise a new unit is part number XFG000040
Post #26444 26th Aug 2010 10:25am
nbunney
Any 1 know where it picks it's feed up from?
Post #26507 26th Aug 2010 6:41pm
andyw
thanks all as usual a fountain of information given
cheapest i found 57 quid so not to bad it is one element of the light so it looks like a complete replacement unit
any one know if it is a plug and play at the top of the tailgate or does it have to feed down a pipe etc
thanks 02 Range Rover HSE Zambezie silver 4.4
Post #26535 26th Aug 2010 10:05pm
@nigel... acording to rave it looks like its fed from the LCM [light check module]
@andy ..again looking at rave , it looks like its got a plug on it , no doubt when you buy the new one it should all be made clear... ... - .- -.
Post #26549 27th Aug 2010 8:55am
Amazed it has gone wrong, LED lights are usually very long lasting, I've never seen a faulty one.... Discovery 4 HSE
Post #26551 27th Aug 2010 8:58am
nbunney
Cheers Scarey
Where is the LCM?
Post #26619 27th Aug 2010 8:34pm
hope this helps...
Post #26637 28th Aug 2010 8:57am
