![]() | Home > Maintenance & Mods (L322) > 12v power source |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Probably easier to do a piggyback fuse feed from the main fusebox in the glove compartment |
^+1 Certainly will. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Behind the left hand side panel is all of the wiring needed for a phone kit |
davidjpowell Member Since: 11 May 2014 Location: Doncaster Posts: 111 ![]() ![]() ![]() |
I'd still have to find a negative/earth.... |
Tell me more... Not bothered about the speakers but the + - would be helpful. Which panel is this? |
Between the heater controls and your passengers knee |
Thank you..... Next (and hopefully last! ) question...
One hidden torq screw by your passengers right toe! Then pull the bottom of the wood panel out (towards the passenger door) held in by the same clip as holds the door cards on, then pull the panel down towards the floor out of the top slider clip... It will then fall off onto the floor and "voila" |
thank you! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8547 ![]() ![]() ![]() |
This is where the wiring is, tapped in here for my Hidden CB, just enough room for its speaker too
You can see the earth point as well far left or far right if you looking upside down..... Pete
Thats it sir |
