Home > Maintenance & Mods (L322) > 2010 steering wheel switches
daveo
hi all, into an other mod...got my self some 2010 switches to add to my carx project, has any one tried fitting these to the early pre 2009 steering wheels, physically they fit,
or may be some one has the 2010 switch wiring diagramme from the land rover site, cant seem to log on.. V8 facelift Range Rover Autobiography 22" wheels.
Post #23402 27th Jul 2010 7:59pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Hi daveo - just wondering if you managed to make these later switches to work with earlier steering wheel electrics Question
Post #25420 13th Aug 2010 5:00am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Sounds like a job for Bobby from RRSport! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #25427 13th Aug 2010 5:43am
daveo
hi, not as yet but it is possible, but its not a straight swap... still getting info and reading other posts. V8 facelift Range Rover Autobiography 22" wheels.
Post #25431 13th Aug 2010 7:03am
SteveMFr
Site Sponsor
Hi Dave,
Just in case you don't have an answer yet, I don't think wiring diagrams alone will help: I've not yet taken the switches apart, but I'm sure there will be a circuit board inside that take your button pushing and turn it into commands that can be read by all devices on the network - in the case of the 2010 switches MOST commands in contrast to the I-Bus commands that you need for your RR.
What I had planned on doing was ripping a pair of I-Bus switches apart and replacing the circuits in the 2010 switches with those. You'll need to build/find a circuit that will send commands from the arrow buttons. You can't do this simply by adding wires as the rotary coupler will likely not have the spare leads you'd need so no way to get from the wheel to the RR...
cheers,
Steve
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #25593 15th Aug 2010 11:24pm
daveo
hi steve, yes you are right about the commands, colin has done this mod on his disco using the same method but not on the RR, I am away on holiday at the moment but will be back and will be looking for a cheap set at the show, if i cann find something thats cracked or missing a button at a good price then i will have something to mess with, i have a new set but want to keep them for when its worked out
dave V8 facelift Range Rover Autobiography 22" wheels.
Post #26278 24th Aug 2010 3:45pm
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
When you say steering wheel switches, do you mean adding 2010 airbag unit? Saw one on ebay at a good price and made me wonder!! Straight swop on 2002??
Post #28118 15th Sep 2010 8:35pm
daveo
hi mate, the air bag is the same and the hole unit will fit but the switches are still under going the mod, the 2010 switches send different messages to the other switches. V8 facelift Range Rover Autobiography 22" wheels.
Post #28123 15th Sep 2010 9:00pm
