![]() | Home > Camping, Caravanning and Holidays > 7 or13 pin |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
funny, my 2002 has a 13 pin on the (original) armature, with a small 13-7 pin screw in converter. -and I would need to use a y piece accessory to change it to a twin grey and black etc. I think you can buy the loom part like this to directly plug into the car loom. ie 13pin
just noticed that mine is full of blue goo. copper sulphate from damp. so will clean it now. could be a potential battery drain there chaps. Last edited by johnboyairey on 2nd Jun 2014 10:55am. Edited 1 time in total |
Buy a new loom part. Depending on year they are slightly different, the 2010 ones are a lot shorter but not overly expensive and vastly superior to the 'Y' type converters which are available.
ksmith100 Member Since: 20 Apr 2012 Location: Stirling(ish) Posts: 77 ![]() ![]() ![]() |
Thanks for the replies guys.
Like most things in life, there are cheap versions of everything. The LR genuine 13 pin socket is hard wired with potting resin at the back to keep it all waterproof and is a very good quality item. Mine was used every fortnight for over 2 years on my old car and was absolutely fine.
13 pin socket is a testable item for an MOT whereas two 7 pin sockets are not. Fitting one just gives something else to fail an MOT. Adapters are not testable items. |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 ![]() ![]() ![]() |
7 pin sockets have been used since i was a lad and probably years before that, Why? because (looked after) they work.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
Disagree with some of the above.
In terms of robustness, i have run 13 pin sockets and plugs for the past 5 years with no problems at all, realistically the LR item is pretty substantial, i have one on the ff and one on the disco and they are both fine after pretty heavy handed use. The plugs on the caravans can be a different question, though they are usually pretty robust, they are fairly easy to replace, essentially its almost the same wiring colours as 12n and 12s so if you break them so long as you have a diagram then although slightly more fiddly, still an acheivable job.
Its a much better solution than adaptors, really is, and the connections seem to be invariably made as i done normally get errors, which i did when using 12n and 12s, and for ref, you cant simply rewire a 12n plug with a 12s plug as the pins are different config. I carry a cheap ebay replacement 13 pin plug in just in case! As for MOT testing, they havent tested meither of mine yet, but at the end of the day if its not working, i would rather know as i use it all the time. I agree its a pain if its something on the car which doesnt get any use, maybe inherited with the purchase, then to fail on it would be a right royal...... There is nothing that can't be fixed with a hammer😜😜 FFRR 4.4 SDV8 Autobiography Santorini Black. KIA E-Niro 4+ 2021 Discovery 5 D300 MHEV commercial Last edited by northernmonkeyjones on 2nd Jun 2014 8:10pm. Edited 1 time in total |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8000 ![]() ![]() ![]() |
It's easier than that
^^ also true, and easy to do, though i would argue marginally less robust, and a lot more fiddly than pulling out the old loom and laying im the new one, about a 15 min job i would say...... There is nothing that can't be fixed with a hammer😜😜
Just because something's as old as the hills doesn't mean there isn't a better solution. If we all followed that logic we'd still be driving the first of the steam powered cars.
My 2012 Coachman came with a genuine Jaeger plug from new so not sure where you get that impression. Possibly some budget caravans have cheap plugs, but they'd have cheap 7 pin ones if those were still in use. Bottom line is that the Jaeger 13 pin plug is vastly better thought out, better engineered and much more reliable. No overloaded earth pins to get hot and melt the plastic, no copper pins to corrode and a positive locking system to keep it in place. |
